(Dismissed) WA Standardized Time Zone Act
Page 1 of 2 1, 2  Next
Post  Arveyres on Mon Mar 31, 2014 2:32 am
World Alliance Standardized Time Zone Act
A long needed bill to make role-play and factbook editing a bit easier. For a long time, I've been extremely confused as to what I should put in the "time zone" area when I am creating a wiki-page or factbook. So now, I have created and I wish to present to you, the World Alliance Standardized Time Zone Act. Not only will this give a new field of depth for roleplay, it will give people to ability to say what time it is in one nation when it is a certain time in their nation.
Now I have prepared to answer some of your questions and comments you may have concocted whilst reading this.
Q: "Why do we need this, it's useless?"
A: It may be to you, but for some it is a nice addition for another dimension of roleplay.
Q: "How will this work?"
A: Simple. If it is 00:00 in Paris, it is a certain time in your nation. If it is 00:00 in your nation, it is a certain time in Paris. This would work alongside the WA Calendar Act, thus giving exact dates and times to certain roleplay events.
Q: "How are the time zones divided up?"
A: Extremely easily. There are 24 zones, equally spaced for each hour on the general clock. The last zone (+12, -12) is divided into two, that line will be called the International Date Line. If you cross it going east, you go forward a day, and the opposite if going west.
Q: "What are the time zones called?"
A: I have devised a list that will follow.
Now for the actual body of the post:
1) The World Alliance Map shall be split into 24 even zones.
2) Each zone will be given it's own name.
3) Each zone will be given it's own time set, either negative, postive, or neutral.
4) The names and time sets of the time zones will be as follows (respectively with colors going from left to right):
- First Red Zone: Alpha Standard Time (-11 PST)
- First Orange Zone: Beta Standard Time (-10 PST)
- First Yellow Zone: Gamma Standard Time (-9 PST)
- First Lime Green Zone: Panaulas Standard Time (-8 PST)
- First Kelly Green Zone: Anglosphere Standard Time (-7 PST)
- First Teal Zone: Eltebena Standard Time (-6 PST)
- First Cyan Zone: Delta Standard Time (-5 PST)
- First Blue Zone: Trapatrical Standard Time (-4 PST)
- First Violet Zone: Tokugawa Standard Time (-3 PST)
- First Purple Zone: Shirouma Standard Time (-2 PST)
- First Mauve Zone: Velikogovolka Standard Time (-1 PST)
- First Maroon Zone: Paris Standard Time (+0 -0 PST)
- Second Red Zone: Okkorland Standard Time (+1 PST)
- Second Orange Zone: Havendes Standard Time (+2 PST)
- Second Yellow Zone: Novo Canuckia Standard Time (+3 PST)
- Second Lime Green Zone: Ireland Standard Time (+4 PST)
- Second Kelly Green Zone: Ivanisgrad Standard Time (+5 PST)
- Second Teal Zone: Kennyland Standard Time (+6 PST)
- Second Cyan Zone: Besançon Standard Time (+7 PST)
- Second Blue Zone: Kyongdong Standard Time (+8 PST)
- Second Violet Zone: Warsaw Standard Time (+9 PST)
- Second Purple Zone: Snarfia Standard Time (+10 PST)
- Second Mauve Zone: Ermeland Standard Time (+11 PST)
- Second Maroon Zone: Newellia Continental Standard Time (+12 PST) & Newellia Marine Standard Time (-12 PST)
5) The central time zone will be situated in the Paris Standard Time Zone (+0 -0 PST).
6) There will be no further divisions of time zones in this map.
7) Time zones with irregular times (not on the hour, i.e. +30 +45) will not be recognized.
Re: (Dismissed) WA Standardized Time Zone Act
Post  Ireland on Mon Mar 31, 2014 2:40 am
I have no objections. Very well written.
Post  Planitan Commonwealth on Mon Mar 31, 2014 2:41 am
I agree with Ireland
http://www.nationstates.net/nation=freedom_planita_2
Post  Texania on Mon Mar 31, 2014 2:44 am
The second purple zone should be named the Pan-Yellasian-Texanian timezone, due to both of us being more active than snarfia
Texania
Post  Arveyres on Mon Mar 31, 2014 2:47 am
Texania wrote:The second purple zone should be named the Pan-Yellasian-Texanian timezone, due to both of us being more active than snarfia
It is not a matter of activity, see the Kennyland Standard Time Zone, I've not seen any roleplay from Kennyland ever, but since his nation is majority in the zone, and it is the largest in the zone, it will be named after his nation.
As for Snarfia, it is an extremely large nation in the area. If you don't like it, you can make an appeal later if this passes.
Post  Ireland on Mon Mar 31, 2014 2:49 am
How long did it take you to make the Map
Post  Arveyres on Mon Mar 31, 2014 2:49 am
Great Empire of Ireland wrote:How long did it take you to make the Map
About 10-15 minutes, why?
Post  Planitan Commonwealth on Mon Mar 31, 2014 2:49 am
We better not expand the map later on, otherwise things are going to go insane
Post  Ireland on Mon Mar 31, 2014 2:51 am
Because its good
Because its good
and good things usually take along time to make
Post  Arveyres on Mon Mar 31, 2014 2:55 am
Because its good
Thank you Smile It just took some dividing and calculating and it was a breeze from there. I hope this bill gets passed!
Post  Imperial Tokugawa on Mon Mar 31, 2014 3:17 am
I agreed with this timelines
Imperial Tokugawa
Post  Ivania on Mon Mar 31, 2014 3:23 am
So if it was 12:00 in Paris it'd be 7:00 in Ivanisgrad because it is PST +7? Time confuses me just trying to understand.
Ivania
Post  Arveyres on Mon Mar 31, 2014 3:25 am
Ivania wrote:So if it was 12:00 in Paris it'd be 7:00 in Ivanisgrad because it is PST +7? Time confuses me just trying to understand.
No, Paris is +/- 0, and Ivanisgrad is +5, so if it is 12:00 (PM, I am assuming) in Paris, it is 5:00 PM/17:00. Just add 5 hours.
Post  Aloia on Mon Mar 31, 2014 3:48 am
Very well written. I approve. But would it be possible to redraw the line (just in roleplay) as it passes through my nation so the western line of Paris time follows my western border? Arveyres has done a fantastic job with this map, and I don't want him to have to actually redo it on the map, but during roleplay it would make it easier if Aloia was just divided into two time zones, instead of two large time zones and just a sliver of the country in a third time zone.
Post  Arveyres on Mon Mar 31, 2014 3:50 am
Aloia wrote:Very well written. I approve. But would it be possible to redraw the line (just in roleplay) as it passes through my nation so the western line of Paris time follows my western border? Arveyres has done a fantastic job with this map, and I don't want him to have to actually redo it on the map, but during roleplay it would make it easier if Aloia was just divided into two time zones, instead of two large time zones and just a sliver of the country in a third time zone.
Oh yeah, the same for New-Zealand, since Auckland is right on a line, you can use one or the other.
Post  Great Eurussia on Mon Mar 31, 2014 6:00 am
@Arveyres, I'm sad there is no time zone named after us. :-( But nevertheless, I'm for it! Nice work!
Post  Arveyres on Mon Mar 31, 2014 6:12 am
Great Eurussia wrote:@Arveyres, I'm sad there is no time zone named after us. :-( But nevertheless, I'm for it! Nice work!
Thanks! You can colloquially call them whatever you would like, but remember your time number +1... etc.
Post  Great Eurussia on Mon Mar 31, 2014 6:17 am
Colloquially? Not officially? :-(((
Anyways, this should be forwarded to Parliament!
Post  Arveyres on Mon Mar 31, 2014 6:18 am
Why to the Parliament? It's already in the Council.
Post  Ireland on Mon Mar 31, 2014 6:22 am
Because this is under Parliament jurisdiction..I think
Post  Great Eurussia on Mon Mar 31, 2014 6:55 am
Yes. You can call for a vote here, to show a full endorsement of this proposal from the Council. The Parliament must enact thia into a regional law.
Post  Arveyres on Mon Mar 31, 2014 7:00 am
So the Council cannot make this a law?
Post  Great Eurussia on Mon Mar 31, 2014 7:03 am
Of course not. I was suprised you presented it here. I thought you are just asking for opinion. By the way, I request and hope that a time zone be named after Eurussia.
Post  Arveyres on Mon Mar 31, 2014 7:19 am
Great Eurussia wrote:Of course not. I was suprised you presented it here. I thought you are just asking for opinion. By the way, I request and hope that a time zone be named after Eurussia.
Whoops, time to present it to the Parliament.
